Hello all,
Just wondering if anyone has had experience with the fault code P062D "Injector Control Module, bank 1 - performance problem"?
The car had been parked up for 4 days, then just wouldn't start. The issue doesn't seem to be battery related as its showing sufficient voltage, with multiple starts being attempted by an RAC patrol. There is a clicking noise coming from the glovebox area when a start is attempted, for a few seconds, and the glow plugs light etc are all showing as per normal on the dashboard.
The engine just doesn't tick over and the check engine light then appears along with reduced engine performance.
The OBD is only showing one fault code; P062D "Injector Control Module, bank 1 - performance problem".
The car was recovered to a garage and has started normally displaying no faults approximately 5 times, until the 6th when the same fault code returned.
Kind Regards,
Mark
Kind Regards,
Mark
