21 - 31 of 31 Posts
I found the Volvo Journal, Part number: 31477917, you need 2 of these.
I work with volvo parts at Swedens biggest volvo dealer so I can find these things.
That's very useful and shows a procedure TJ VCC-498307-1 in one picture.
Can you identify the procedure reference for UK right-hand-drive vehicles please, or is it the same?
I'd like to show that to my dealer.
Reactions: HenryNcl
Super Moderator
Have the same more bubbling less hissing sound from the center console or right footwell (LHD-Greece). Read all the thread, can not understand if anyone found a solution. Does the aircondition need recharge? This seems more probable, than changing any part. What do you say ?
Had the new sound proofing fitted yesterday by my dealer as Theos post and noise has gone. I was able to generate the noise by turning the air con up and down previously but thankfully all silent so far, definitely worth aski6to have this fitted. Raytint, that's exactly where noise seemed to be coming from right foot well but the pipes are actually behind the dash.
Everyone is saying "aircon" here, but do they mean ventilation?
When I turn my aircon (cooling) off the noise remains, it only varies with ventilation fan speed.
That said it's cold here (England) at present so the cooling function is probably not active...
No its definitely an aircon noise, it's the gas going through the evaporator, if you turn off aircon the noise stopped. If noise doesn't stop when aircon off it's a different problem
Super Moderator
I agree with you, Trevor. The hissing ventilator sound, which goes up and down accordingly to the fan speed is a known problem with V40. It impressed me a lot for a premium (say...) car in the first days, but now I am familiar with it. The sound in my car is a faint bubble - gargle sound, like liquid mixed with air circulating in the pipes, and it dissappears when the aircon is shut down. I wonder if anyone has a definite diagnosis for this, and, of course any kind of solution. It was Jamie Mulligan who started this thread that described it exactly as I say, and this is a question directly to him for any solution. If the system needs recharging (gar replenish) then I will do it.
Hi All,
I've just got my 2017 (67) V40 R Design Nav Plus and the a/c makes a similar noise when on. At first I thought it was coming from the wheels as it seemed to be more of a whirring sound like something going round and round. Soon noticed that the noise only appears when the a/c is on and then disappears straight away when the a/c is switched off.
Is this something that they'll look at under the warranty, especially if there's a known issue and potential fix for it?
I have the same hissing sound when the A/C is on at my T3 MY2016. Sound goes away immediately when A/C is off. I will make a question at the dealer next time I visit for yearly maintainance.
V40 D3 2013
My update to this issue: big thanks to @theodorkalin for part numbers and instructions. Put in new insulating material myself and now the noise is gone!
A few notes: instructions say you need two pieces of insulating mat. I only managed to use one mat for both pipes :rolleyes:
Had to cut quite small pieces to get them to fit well over the bends, the mat is aluminium covered bitumen mat with a strong glue underneath so it sticks to everywhere it shouldn't.
Also the location of the pipes is not so very nice, very cramped. Even with small hands I was struggling to fit the insulation neatly on the pipes.
Paid in Finland 8 euros/mat so a cheap fix for an issue that was almost driving me nuts; otherwise pretty quiet car but with bubbling and hissing in the foot well 🤬
Hi everyone (It's my post ever post here)!
I've got the same hissing problem and would like to fix it as well. However, I couldn't find the insulation part with the part number given kindly by @theodorkalin. I googled it and it offered me some kind of insulation part for door of another model. Is there a specific place to look for it? Also, as @Phosphated mentioned, the mat being aluminium covered bitumen mat, would it be possible to use any such mat available in an auto parts store? How thick is it? Or could some kind of insulating adhesive tape be an option?
Thank you for your answers in advance!
V40 D3 2013
Sorry for late reply, your post slipped past me somehow.
I googled the part number again and you are right, it shows it being a door insulating mat for a XC40... and XC60... and XC90...
So my guess is that Volvo classifies that mat as a all-in-one solution for all kinds of noises 😄
Sure, why not, it works probably very well to dampen vibrations in large panels.
That is the mat I bought and it fit on the cooling pipes very well, surprisingly I also only managed to use only one when you are supposed to use two?
To your question about a general auto-parts bitumen mat, my advice would be: no, don´t.
This mat was very flexible, a lot more so than other bitumen mats I have handled.
It also had very good glue, that is why I was able to cut small pieces that fit well and not be scared of them dropping off.
21 - 31 of 31 Posts
