I tend to rely more on the "distance to empty" reading. Is this malfunctioning as well?My fuel gauge appears to be stuck on red. No matter what I do, how much I put in, it's just permanently stuck.
Ah yes, makes perfect sense! Thanks for the advice. I really hope I don't have to go through that whole "no fault go home" business... It sounds frustrating enough just reading about it here.they will no doubt say it is working fine and no fault detected, nothing they can do, take it asap, show them it on red but with plenty of fuel in (obviously make sure it has plenty of fuel in, then tell them to drain the tank and measure the fuel, and also that you will expect them to replace it (not just stick it back in as could not be contaminated) on the basis that you had to take it with loads of fuel in to show them the fault as other wise they would have just sent you away saying no fault etc.
hope this makes sense
NB I have had this...there is no fault, you ar emaking it up form other marques e.g. ford, BMW, Audi, VW, Seat etc.
I certainly wouldn't accept that "it's just something that happens".Well, after a trip to the showroom, I've been told basically that it's just something that happens & there's nothing they can do.
Indeed but by hs last post it appears they accept the fault exists but he just has to live with itLooking at the first post by the OP it looks like an intermittent fault - cleared in 8 hours. So this may be an issue for the dealer. No excuse though for not sorting it out.
Unfortunately, intermittent faults are notoriously difficult to diagnose.I would think if the fuel gauge is faulty the dealership would hard pressed to ignore?
