1 - 12 of 12 Posts
Well, my car is in Volvo for investigation on coolant loss....wish me luck 馃馃従馃馃従馃馃従馃馃従馃馃従馃馃従
Well, 1 head gasket later.....everything seems fine so another couple of years of motoring out of it 馃憣馃従馃馃従
Discussion Starter · #6 ·
So yeah.........its back in again, a thudding from the top end accompanied by a rattle at high engine speed and loss of power 馃う馃従鈥嶁檪锔 I'm gonna lose my rag with this car if this keeps up.
Got a 21 plate XC40 for a courtesy car though so not all bad馃憣馃従
Arrgh, I'm also leaking coolant but seems to be from the heating matrix. Only see a leak when I put the heating on. Odd thing is the liquid leaking out seems to be just water, no dye from the coolant...
Also no water in the oil, thank goodness.
I've seen this issue quite a few times on this forum and have found one solution that always works.
Part ex.. (y)
Discussion Starter · #10 ·
Turbo has been replaced, water pump replaced, aux belt replaced, cylinder head gasket replaced....hopefully sorted 馃馃従
There'll be a crack in the block.
1 - 12 of 12 Posts
