A few question about the USB port, the dealership couldn't answer me...
- can you connect a usb hub or Y-Splitter to charge your phone *and* connect a usb key at the same time?
- can you connect a 2.5" usb harddrive and power it through the usb port alone?
- is the usb port powered even if you're not playing music from it?
- is the usb port powered when the car is turned off?
- can it play from a Samsung Galaxy S2? (it mounts more than one drive when connected through USB) or will I need to use Bluetooth streaming?
- Is there a size limit to the disk or will any size do? (limited to fat32 max size f course)
And a similar question about the bluetooth carkit, will it allow you to attach two phones at the same time? I usually travel with both a company and a personal phone
