Seems like the timer on the rear heated window is broken I.e. it won't switch off automatically. Anybody know of a quick fix? I fear it means taking it to a dealer to fix.
I have read that it does go off automatically. I can drive about 8 -10 miles before it goes off on my V50. Not sure how long you are leaving it before you give in and turn it off yourself.
Only one other thought is that you can set the car up to switch the heated windows on automatically if it is below a certain temperature on starting. If you have done this maybe it does not switch off as long as the temp remains below that level?
Thanks for all your responses. I looked at the setting for auto on and that's switched off. Maybe I'm not waiting long enough as you suggest (although I'm sure it's been on for at least 20mins). I'll
Monitor more closely. It's certainly meant to go off as it says in the instruction manual.
