Hello everybody, although new here, I've read a lot in this forum, and yet it has helped me a lot.
So I have recently just purchased MY2016 V40 2.0 D2 with R-Design Business on it. Everything works perfectly - except for the heated windscreen. As I've understood in this forum by previous threads on this, the heater elements are divided into two circuits. I've checked the fuses - they're all OK, and tried switching them - still, only the passenger side heater element section works. Dealership diagnostics, which was mandatory before purchase, have shown no faults
Maybe someone has a clue on what could be going on here? Maybe some connectors could be failing, or the only answer is changing the windscreen?
Also, I've thought of retrofitting the rear camera. My Volvo has the option code 802 and is fully ready for installation. Maybe somebody knows where could I buy the kit (sensus installed)?
Sounds like you need a new windscreen. The dealer should be able to access the wiring connections and test the resistance of each half to confirm.
Reactions: Amadėjus
Well yes, the dealer could do a lot, the problem is I just can't find any wiring diagrams for the connectors regarding the windscreen heater power supply. On VIDA, I found that there's a replacement part for that specific cable, but no clue on where that cable is located. Maybe someone has the wiring diagrams for V40?
If you bought it from the dealer take out back to them it's their problem, especially early on.
Sent from my HD1903 using Tapatalk
I doubt there are any wiring diagrams of the V40 out there, i got a virtual machine running with full VIDA on it, i can check for you if i can find any.
