Hi all, I'm looking for help with a problem. The error message I'm receiving is as the title states. I'm driving a 151 V40. Diesel. 60,700 miles. I'm the second owner with two years without a problem. It started as a 'coolant level low' issue a few months back. We had a frosty snap two weeks before Christmas and I realised after a few mins driving one morning I had no heat. Heaters continued to blow cold. After leaving it to my mechanic we found I was getting heat through when I was able to reach high speeds but after a few minutes the 'High Engine Temperature Reduce Speed' message would show and quickly progress to 'High Engine Temperature Stop Safely' and pulls back the power in the car.
He has not been able to find the problem so far after numerous investigations. The 'Check Engine' Light is now also on since installing a new timing belt and water pump.
List of what has been done:
Radiator flushed 3 times (quite a lot of muck was emptied)
Thermostat housing replaced with new as it was not opening or closing properly with more 'muck'.
Timing belt and water pump have just been replaced, which were due. This is the last thing that has been done.
Internal radiator is the next possibility I'm facing.
Anyone else experience this problem? Thanks in advance.
