1 - 10 of 10 Posts
quick question that has probably been asked already, so sorry for repeating.
How is the gear knob illuminated on the R-Design ?
Is it done from within the gear knob or part of the theater lighting shining down on to it ?
It's lit from within the gearnob.
Thanks,
I only asked because my previous car had an "illuminated gear knob", which was basically a small white LED that shone down from the headlining onto the gear knob, it was useless if I'm honest.
The original type of gearknob worked as a light pipe - there were two LEDs shining into the edge of the clear plastic at the base, and the light would then escape everywhere there was an edge (like the edges of the numerals, gate pattern and knurled edge that were moulded in the back of the plastic). There was a mirrored surface behind to help reflect the light outwards:
Is this the current manual gearknob?
This will be made of 2 types of plastic - a translucent white inner which then has the black outer moulded or cast over it. The LEDs in this case are under the white inner plastic, which acts as a diffuser.
On the older one at least, the LED brightness is linked to the footwell and dash illumination adjustment.
Yep, that second picture is what we have in a MY15 car. And the brightness is still adjusted with the other lights.
Discussion Starter · #6 ·
Can the colour of light in the gear knob be altered like the cabin theater lighting ?
No, it just glows a very dull white.
Its a shame as i much prefer the older style one that has actual colored LED lights in it. Marketing this a illuminated gear stick is a bit of a cop out. But the theatre lighting is ace and the car drives so good that im not that fussed anymore :)
The old manual knob only has while LEDs too - only the automatic one had the coloured LED strip in it that showed what position it was in.
hi, what is part number this gearknob?
1 - 10 of 10 Posts
