1 - 2 of 2 Posts
Hi all
Am replacing the hose (from intercooler to throttle body), as mine currently has a couple of splits.
How do I get to the bottom hose clip? Is it a case of removing the under tray, or is it a bit more complex?
Thanks all
Cheers
Danny
Hi friend, you need to remove big plastic with screws from the botom, then you using screwdriver to unscrew the metal clip from the pipe, of course the same from the turbine (above).
Definitely you'll need to put the car on the lifter to approach it from the bottom side. I hope this will help you little.
1 - 2 of 2 Posts
