Looks good so far - I'd have been tempted to colour match them to the bodywork - they would look good in rebel blue.
No glue, just pressed in. You can pull them away gently, but not too gently, theyre quite tight...Thank you. I was thinking about how to take off the door trims. Is it just clips or is it glued?
thank you for the info. I will post pictures when I’m done painting them 👍🏻No glue, just pressed in. You can pull them away gently, but not too gently, theyre quite tight...
