If the front passenger seat is folded, you can load a slim object as long as 240cm.
The length obtained by folding a front seat must be greater than 50cm, so 190cm ski may not be laid in the boot with rear seat folded.
If you need passenger seat, buy a roof carrier.
I have just measured mine for you. From the rear of the drivers seat to the inside of the ledge across the back of the boot is 155cm.
Thank you! :) So I need to order roof bars and box.
I assume you've got the skis but not yet got the V40. If that's the case, why not go to your dealer with your skis and ask whether you can see if they'll fit into one of their demonstrators or used V40s? If they quibble about it, then just say that you'll cancel your V40 order if they won't let you!
