Gear shift Automotive design Gadget Automotive lighting Vehicle
Automotive lighting Automotive tire Camera lens Hood Motor vehicle
Hi guys, if someone had anything similar happened to them it would be good to get some suggestions :)
My gear knob has become a little bit loosened near the top and I have attempted to glue it back into place but as you can see it is on an ideal approach.
Did anyone tried to fix this issue?
As you can see the rest of the gear leathering is pretty much new and if I would replace anything I would be looking only at the knob.
If someone has some replacement products to try out, I have found this but I think it will not cover the part that is changed.
Drinkware Sports gear Audio equipment Gadget Personal protective equipment
Thanks in advance!
