Middle of road here, as an engineer I have always run mine in, under 3k rpm for 2,000 miles no labouring engine, vary revs and change oil to Mobil 1 as soon as it starts to colour, usually 3k - 4k miles.
Modern cutting tools, high speed machines and materials mean far better surface finishes are produced, meaning more slip and less friction from the off - hence no recommended run in periods.
I used to change oil at 1,000 miles when it coloured (from paticles shed when wearing in), but in last few new cars I have noticed oil lasts far longer before colouring, so yes things are far better and running in is less critical, if not useless.
I will drive mine easy for first 1k miles and see how oil looks, if no colour then no harm in pushing it.
Golden rule for the life of the car is never take a cold engine over middle of rpm range & never let it labour.
Once it's warm through (5 min after hitting middle of temp gauge) bend the rpm needle as often as you like - ahem drive it in as econical fashion that suits you
