The 2050 RPM I quoted was an approximate figure. If you interpolate in the above table, you get a closer result of 2041 RPM. If, however, you use this http://www.club80-90syncro.co.uk/Syncro_website/TechnicalPages/TRC%20calculator.htm to get the dynamic rolling radius of 307 mm, in conjunction with the gear ratios, the speed is 2028 RPM.............. I then used this to calculate the information you require. http://www.car-videos.net/tools/spe...io7=&Redline=5000&Increment=50&B1=Recalculate
