Power outlet, luggage compartment £95 (Fully Fitted). Although these are fitted as standard in every other Volvo, as far as I know, it is an optional extra for the V40. But it doesn't appear in the brochure, so you won't know until the car is delivered. I bought the part, socket and wiring harness, and fitted it myself for about half that quoted. It took about half an hour. You will find the fitting instructions here http://accessories.volvocars.com/AccessoriesWeb/Accessories.mvc/en-GB/RU/V40%2813-%29/2013/D4/Automatic/L.H.D/ShowDocument/VCC-446258
The only problem I had was that the nut on the socket didn't tighten down to the panel. I had to make up a spacer about 4mm thick.
