Where is this bolt located, and what should I be looking for ?Just for information, I decided today that I would remove the fixing bolt on the leading edge of both my rear door panels as a "just in case it ever happens to me" measure. This is the one that can't be accessed if the door is unable to be opened and which results in removal damage to the door panel. On my 2017MY car, it appears that the bolt is no longer fitted. The door panel moulding is continuous with no covering cap or hole where the bolt should be located, so it appears that it has been modified to simplify removal if the door is stuck shut. Pity they couldn't just modify the locks so that they didn't need replacing.
