Hello all, so I replaced the rear view mirror yesterday. Honestly, loads of fun
So the mirror itself pops off the stalk which was fairly easy, then putting the new mirror onto the stalk was a pain. I pushed a little to hard without supporting the back enough and pulled the stalk/mount off. Refitting the stalk/mount was awful but after removing the plastic trim it was easy. It goes on 90 deg facing the passenger side and then twist it back central. There is a earth cable that needs to go back into the stalk/mount if removed. Then re-add the plastic trim and finally attempt again with the mirror.
Also I noticed the stalk/mount I got with the new mirror was different in size and shape to the old so I kept the old.
This is the connection point that the rear view mirror stalk/mount connects to.
Left =old mount vs right new mount, Volvo part numbers on show I case anyone needs one. Shouldn’t though as they look like casts.
Left old, right new.
Same connection.
This is the connection point with everything removed. Trim was really easy to remove, start at top right, then reassemble start at top left after it has been fed over mount.
New mirror in place.
Any questions give me a shout.
Same connection.
