Can anyone advise me if they have found any improvement with so called quiet tyres. This is my first V40, road noise is my only issue !
Do the 16" make for a quiet ride in respect of road noiseNo, my car is on 205/65R16 tyres on original alloys from new. I'm not a fan of tyres below about a 55 profile. Each to their own, but I think that large wheels and very low profile tyres look ridiculous, even more so on off road type vehicles that become completely incapable of driving up a kerb without a high risk of tyre or even wheel damage
They are fashion over function I'm afraid. Any handling advantage they might have over higher profile tyres is completely unusable on a public road, and the state of many roads these days means a proportionately higher risk of expensive tyre or wheel damage and passenger discomfort. They are just a fashion accessory for the bling brigade that serve no useful purpose whatsoever. Sorry! IF the overall wheel and tyre diameter is the same no matter the sixe of wheel and profile of the tyre, how can they look too small for the car, except from a modern fashion aesthetic?
But I can appreciate the benefit of slightly larger wheels on the more powerful variants to accommodate larger brakes.
I certainly have no complaints. In fact my V40 is far quieter than my previous car and encourages smooth driving, as it just seems to glide along. There is very little in the way of road noise or jarring over uneven road surfaces, and I would still describe the handling as superb.Do 16" make for a quiet ride in respect of road noise?
As you say, each to their own.No, my car is on 205/65R16 tyres on original alloys from new. I'm not a fan of tyres below about a 55 profile. Each to their own, but I think that large wheels and very low profile tyres look ridiculous, even more so on off road type vehicles that become completely incapable of driving up a kerb without a high risk of tyre or even wheel damage
They are fashion over function I'm afraid. Any handling advantage they might have over higher profile tyres is completely unusable on a public road, and the state of many roads these days means a proportionately higher risk of expensive tyre or wheel damage and passenger discomfort. They are just a fashion accessory for the bling brigade that serve no useful purpose whatsoever. Sorry! If the overall wheel and tyre diameter is the same no matter the size of wheel and profile of the tyre, how can they look too small for the car, except from a modern fashion aesthetic?
Yep. And I'm from an era where low profile tyres were the 70 series boots on my RS3100We could go around in circles (excuse the pun), with this though, as it's all down to personal opinion.
I put up with the extra road noise as I think the car looks better with 18's, perhaps 17's at a push, but I wouldn't put low profiles on a 17" rim as it would look too small in the arch.
Each to their own eh !
ahh, off topic but one of the coolest cars from the 70'sYep. And I'm from an era where low profile tyres were the 70 series boots on my RS3100![]()
I thought that discussion was already over, and I said each to their own right from the start.As said already, it's horses for courses.
Looks and style or comfort I guess is one way of looking at it.
Anyway gentlemen from a certain era should not be hacking someone else's post with their own agenda, so let's agree to disagree and give the post back to the donpauline123![]()
It is, but for any vehicle, only certain tyre size and wheel size combinations are approved by the manufacturer, or can be physically fitted without fouling bodywork etc.Less tyre wall = harder ride and more road noise.
More tyre wall = softer ride less road noise.
Personally I'm not sure if a smaller diameter rim would add or lessen the road noise as I would of thought it's the hardness of lower profile tyre walls and the distance from road surface to the rim that increases the noise.
Yes, Volvo fit spacer block to each end of the steering rack to limit its travel, and reprogram the power steering control module with new software that creates a resistance when approaching full lock, to limit the possibility of the spacer blocks damaging the rack. You could call it a cobbled together solution to allow larger wheels and tyres to be fitted than were intended when the car was designedOne thing I have noticed is the slightly reduced turning circle with the 18" rim, apparently due to some sort of restrictor being fitted to stop the tyre rubbing against the arch ?
Ford also do on the early fiesta and Ka, even for a 15".Yes, Volvo fit spacer block to each end of the steering rack to limit its travel
