Thanks for the info and the tip and will try and save addresses as my favorites.MichelR said:As far as I know you can not save a route.
You can save addresses of place you regular go..
You can add a voice command to these so that you can use the voice input to quickly setup the route.
A tip don't forget to turn of toll roads if you don't want to use them.. Found out the hard way..
