I think that's what it is. I saw a similar thing happen on a Fifth Gear TV programme in which the presenter was testing a start-stop Renault Megane.I wonder if that is a battery saving feature? Might be the car knowing the battery use is high and the engine needs to run before it loses too much charge? If so, its a good feature![]()
I just wish that car manufacturers would offer the system as an optional extra, and give cost comparisons of with and without the system.Are you satisfied with how it works ......
I think the start/stop system only stops the engine when, amongst other things, it decides that the battery level is high enough and the electrical load at the time is low enough. Even if the battery level was low when the engine was started after a period of inactivity, I would expect the battery to very quickly become sufficiently charged. And because the system doesn't work until the engine/coolant temperature is high enough, it's difficult to know what's happening. I think you'd need some sort of complete failure of the system before any problem could be diagnosed. I'm sorry I can't be more helpful.Any answers to the above questions ?
Hehehehe. I guess one scientific test would be to leave the car engine running for 24 hours on your driveway with a full tank of fuel and then make a comparison against the same car on your driveway with a full tank of fuel with the engine switched off to determine which has used the most fuel.I just wish that car manufacturers would offer the system as an optional extra, and give cost comparisons of with and without the system.
(a) Effect on fuel consumption.
(b) Effect on maintenance costs.
I've yet to see the results of any scientific tests showing that start-stop is in any way beneficial. I suspect that in reality it's a bit of a gimmick.
"it decides that the battery level is high enough and the electrical load at the time is low enough." Most probably your intention was to say it vice versa. The battery is not this easily recharged to an operational level, and even when the coolant temperature is high enough, the phenomenon persists. Anyway, the car seems to be in a complete failure of the system, but I am not that anxious to get it operating in terms of fuel economy (I have read many articles about start stop not being that fruitful - most probably the best one was proposed by you). I just want it to operate smoothly, as it did in the past. The persisting failure appeared after a quite long period of the car being inactive (maybe 25 days) and according to Volvo dealer it is because of the alarm current consumption. Anyway, thnx for the hints, will let you know the reason, if and when repaired.I think the start/stop system only stops the engine when, amongst other things, it decides that the battery level is high enough and the electrical load at the time is low enough. Even if the battery level was low when the engine was started after a period of inactivity, I would expect the battery to very quickly become sufficiently charged. And because the system doesn't work until the engine/coolant temperature is high enough, it's difficult to know what's happening. I think you'd need some sort of complete failure of the system before any problem could be diagnosed. I'm sorry I can't be more helpful.
