TDI Tuning Box Systems
Hi Imafudd,
TDI-Tuning is a specialist tuning company and offer both remaps and tuning box systems.
We achieve great results from the CRTD2® with the Volvo V40 1.6 D2 113 Bhp / 115 PS / 84 Kw with improvements in both power and torque whilst improving fuel efficiency. This PSA engine is a very common engine for us. The same engine is also used in Ford, Peugeot and Citroen brands.
Don’t just take our word for the results, if you refer to our Facebook page -
https://www.facebook.com/tdituning you will see some very positive feedback from our customers with this exact engine.
Lots of points have been raised on this thread so I will try to cover as many as possible, so this maybe quite a long post!
In terms of how the systems function, they plug into your engine between the ECU and engine sensors. They receive and optimise the signals sent from the ECU and will increase and improve torque delivery. With the extra torque available, you can stay in a higher more efficient gear for longer, directly attributing to improving your economy.
Tuning box systems are able to safely release extra torque from an engine as manufacturers sell their vehicles with untapped torque locked in their ECU’s. This is for two main reasons –
1) They will use one engine for a range of different power variants but control power through the ECU so their ‘lowest spec’ model is actually a restricted version of the top spec version.
2) They have to ensure that their engines are able to operate adequately in a wide range of global environments and have to factor a large degree of tolerance into the engine to deal with this, often at the expense of users who purchase their vehicles in environments that have a high quality European fuel supply.
With regards to some general information on our tuning box systems, they are traceless and therefore are not traceable on your ECU. If the system is removed, the vehicle will immediately go back to its standard factory settings. Therefore, the tuning box leaves no history of its use. Our tuning box systems can also be installed and removed easily and can be fitted by you in a matter of minutes.
Our systems are also custom programmed based on our customer’s specific requirements and have multiple maps for easy adjustment. They can also be reprogrammed for any future vehicles at a small cost.
It’s common for customer’s to ask us about the impact it may have on their vehicle before purchasing a system. The tuning box will not cause any detriment to your vehicle. It will not affect your engine life span and will work within the manufactures tolerance on engine components.
With regards to your car insurance, we advise all of our customers to notify their insurer of the tuning system, as you would do if you made any modifications to your vehicle.
We offer a 14 day money back guarantee, so essentially you can trial the system to get a feel for the results. If you are able to visit our office in Chelmsford, Essex we offer a ‘try before you buy service’, we will also fit the system for you free of charge.
If you have any general tuning questions, you are very welcome to call us for a chat on 01245 392255.
Kind regards,
Steve
www.tdi-tuning.co.uk
