Just made sure my tyre pressures are correct and hoped to calibrate them via the my car settingson a drive however the option to calibrate (the only option that appears) is greyed out and no amount of pressing OK seems to work, the 4 tyres are all showing green on that same menu screen.
Anyone know what's going on with this? I've read about many issues with the system so perhaps it's been deactivated!? Only just got the car as a 1 year old ex demo, MY15.
Cheers in advance for any possible explanation
When engine is running in neutral and stationary you can select calibrate then go for a drive, when the engine is turned off the option to calibrate will be greyed out.
Normally when I check my pressures and add air I'll recalibrate.
Mine is greyed out when the engine is running. However it is white when stationery with engine running. As soon as I drive off to recalibrate it goes grey so not available.
