1 - 17 of 17 Posts
Hello team!!
Doe's anybody know what probably means that usb goes to ICM ?? on the electric diagram (refers to performance sound system)
Schematic Font Rectangle Technical drawing Parallel
I'm not sure if it can be retrofitted if you don't have performance audio.
It is used as an iPod/phone/ connector, as well as USB mass storage for music and finally for updating the satnav
But I have performance audio:aux only,two speakers only on front doors,no bluetooth,no usb,no amplifier...I think that's performance.
That's why I wonder what's that USB is...
iirc the performance audio had all the things you mention (eg multiple speakers, amp, dab etc)
4 specifications levels of infotainment equipment:
Level 0 - Performance (Radio/CD/Aux, 5" screen, integrated amp)
Level 1 - High Performance (Radio/CD/USB/Bluetooth, 5" screen, 4-channel AUD amp module)
Level 2 - High Performance Multimedia/Nav (Radio/DVD/HDD/USB/Bluetooth, 7" screen, 4-channel AUD amp module)
Level 3 - Premium (Radio/DVD/HDD/USB/Bluetooth, 7" screen, 5-channel AUD amp module)
The USB connection in Performance audio is for updating the unit only by Volvo service..
You're killing me....
Are you sure?cause on the same wiring diagram when refers to premium audio seems that usb goes on IAM not ICM.
The audio system ''Level 0 - Performance (Radio/CD/Aux, 5" screen, integrated amp)'' was the basic audio unit and does not include usb for music. The premium systems (Level 1 - Level 3) have USB for music that's why is connected to IAM unit..
Discussion Starter · #11 ·
I see...now I get it...thanks for the explanation at least answer me please to that (καθώς βλέπω είσαι έμπειρος και γνώστης)(I think we discussed that on another post).if I have already done the ITP off, may I change the 5 screen to a 7 one?and it has to be specific version with number HWN 31357076 vertical on it?
Yes that is correct.
Discussion Starter · #13 ·
Happy new year Haralampe ! Hronia polla kai kalh xronia!
i followed the steps and i have now a 7 inch screen 31357076 and the dashboard 31393107
Yesterday i tried to install it and it was total black.....
one thing i figured out is that on my 5 inch screen witch has 3 connectors , one is power lin ,the second is optical, and the third small grey is a usb that is unneccesary cause i disconnected it and 5 screen was perfectly working without it and also i don't have a usb port in the armrest. so i guess it ends somewhere in the harness like a preinstallation...
now about 7 that was !!BLACK!! are you sure that the software 31373032 is not necessary ??
cause 7 is from another model and year i think from a v60.
i have done ITP installed but thats for security right? so i can install used parts now
but the car has to know that right? 31373032 software is to inform the car that has a new screen right?
sorry gia to makroskeles keimeno alla pragmatika de vgazo akrh kai tha ektimhso kathe plhroforia
Good morning .The software 31373032 is not necessary. Maybe the issue is the used screen, maybe is damaged... Where are you living?
Discussion Starter · #15 ·
i live on creta island. 7 inch screen is in a very good condition i think it was from a v60 and at my searches 31357076 part usually goes with IAM 2.1 level 3. so i believe that its not compatible with my IAM 1 level 0.
I did the same update (same screen) and everything worked directly . I see 3 possible faults :
Α) Ι had IAM Level 1 unit (Bluetooth, CD, rear speakers..) and not the basic media unit (only front speakers, no amplifier under co-driver seat..)
Β) Is the ITP most remove software installed successfully ...?
C) Faulty 7'' screen..
Discussion Starter · #17 ·
I guess it's the first one ,cause I've read in several posts that screen upgrade is not possible with basic IAM ...I need at least 2.1level 1 like yours to succeed. The screen I believe it's not faulty just not compatible. And at last itp was installed at official dealer cost me 120eu. im searching for another iam now lets see how it goes.
1 - 17 of 17 Posts
