Hi!
I have taken my car into my local Volvo Specialist today to have some bits done to it, and they have given me a V40 T3 as a courtesy car for the day. I've noticed it has a sizable difference in power and actually does more mpg! I've seen on the forum that the T2, T3, and T4 are identical mechanically. So, I am wondering if anyone has had a remap (if that's what it's called) from a T2 to a different power spec, where is best to get this done, and how much it has cost people in the past.
17557
Many thanks in advance.
Is your car the 1.6 T2? I assume so from the picture. If the courtesy car was a face-lift model, then it would be the 2.0 T3. While the HP figure of the 1.6 and 2.0 engines are the same, I wonder if in reality the 2.0 models have a bit more poke.
2017 T2 R-Design
The T2 T3 and T4 having same engine only applies to VEA engines, yours is a Ford derived one. But that doesn't really matter, as yours can be also remapped, probably with similar results.
Have a look at this link, it will give you an idea of what to expect.
Yes, I'm guessing that's true on the manuals, all 2.0 turbo engines, though I can hardly call a 122bhp T2 2.0 a turbo as a well come on, back in the day had a Honda Accord 2.0 non-turbo outputting 150bhp.
Autos, it's a little different on VEA, T2/T3s were 1.5, and T4 was still 2.0.
2017 T2 R-Design
My previous Civic output 138bhp from a naturally aspirated 1.8.
Wonder how far the T2 could be safely remapped without having to think about cooling solutions or changing flywheels/gearbox due to premature wear
Discussion Starter · #6 ·
I took it to a place in Bridgend yesterday, and they have confirmed that Stage 1 is safe for the car, with them all having the same engines etc. I believe they quoted around 190 BHP now and I have to say, so far it does look like the fuel economy is better than before. I may go back and get it tuned down a bit depending on recommendations on ensuring no undue stress is put onto the engine etc, but I will see!
Glad to hear that the remap has made a positive difference. I'm getting my T3 2.0 remapped so reassuring to hear this. I think 190 bhp sounds good as that's just taking to the T4 level. I wonder if some of the tuning is not just turning up the boost - I got peak boost of about 7PSI on mine as stock and from what I read is nearing the limit on a 11.3:1 compression. Maybe a remap could take this to 9PSI, but it's possible gains are made elsewhere as the 2l engine should be able to deliver over 150 as n/a.
I'm no expert - just armchair research so maybe others have some more insight?
