Hello people.
My UK '13-plate V40 D2 is intermittently making a noise that I can only describe as a "groan".
It's happened on and off since April '13 and it used to be only ever when the auto-braking system kicked in if I'd stopped in traffic on a hill (travelling up the hill)... once I'd stopped, sometimes as I start to move forward again it there's a "groan" type noise. The noise is audible both in and outside of the vehicle.
It also makes the noise if travelling slowly up a hill and using the bite-point (e.g. in crawling traffic) and if I stop whilst using the bite point to maintain position the groan is continuous (on the occasions that it does it), until I stop the vehicle and switch to foot/hand brake, but then when I start moving again, just like the paragraph above, it'll groan as I begin to move.
I initially thought it was something to do with the brakes, but at its first service I raised the issue with the service guys and later on they said that everything appeared to be in order. At its second service I raised the issue again and once again they told me everything seemed to be in order. At the second service (circa 24,000 miles) the front brake pads needed to be replaced but in addition the rear brake pads were 75% worn and I was encouraged to replace them too (which I did).
However I'm beginning to wonder if it's actually to do with the clutch... there's a particularly difficult junction en-route to my home that sees me coming up a hill to a T-Junction and turning right on the crest of the hill. It's not really feasible to do anything other than use the bite-point to maintain position in order to both maintain visibility over the road I'm joining and achieve a quick/smooth exit when the opportunity presents itself, however on two separate occasions now (both times prior to the recent second service), with the vehicle "groaning" I've set off to turn right from that junction and when I've come to change to 2nd gear, found the clutch pedal to be stuck down, requiring me to put my foot underneath it and with a little lift, it pops back up. I mentioned this to the service guys too and it was all but shrugged off.
I'm no mechanic... I'm a computer geek.... I'm tired of raising it with the dealer, only to be told that everything is in order... surely something isn't right?
Has anyone else experienced it?
