When I use the voice system to access the phone contacts (using the command "Dial > Phone Contact") I get a message saying "Not available at this time". Can's see anything in the manual which explains why this might be the case. All of the contacts are available to dial using the manual (i.e. buttons) system, which I find a bit clumsy and not something I would try while driving, so getting the voice activation working is important. Anyone have an idea???
I usually see this when the phone is still synching. Does it work a few minutes later?
I thought I had allowed sufficient time for it to synch ... I'll try it later and see if that could be the explanation. Thanks
It does sync on each and every connection.... So that could be it..
Yes, it works after a few minutes..takes longer to synch than my other car. However, it doesn't seem very accurate in interpreting which contact I am looking for. Probably need to spend more time with it.
