Hello guys,
After some online research I found out that v40 D3 and D4 5cyl from 2013 have the same engine and gearbox. Are there any risks involved in remapping my D3 to D4 factory map and could someone please tell me who are the best people to ask for the map? Many thanks
I thought there were different turbos only for the VEA engines,4 cyl, after 2014, please correct me if i'm wrong
Yes, you are rightm I was thinking about 4cyl, I see that you are asking about the 5cyl engine. I didn't know there even was a D3 5cylinder engine.
I suppose it can be tweaked quite a bit. Just take it to a decent tuner and let them have a go at it.
You can have a look to RICA Engineering.
They have a special "box" that allow you to switch from standard ECU maps (150 Hp) to D4 ECU maps(177Hp)
And if it's not enough, Stage 1 ECU maps (200 Hp)
The only problem is that you need to remove the ECU and put it in Boot-mode ( something like rooting your smartphone)
They can did it if you send your ECU.
