1 - 10 of 10 Posts
On occasions when pulling away from stop there is no response, then all of a sudden the power returns when I press halfway with the accelerator the car goes with a jerk, this sends me lurching forward, could it be water in the diesel?
Paul.
If it coincided with either filling up or running the tank to nearly empty maybe. Water usually sits in the fuel filter.
Thanks for your reply hullu, It can happen with a 3/4 tank, at the moment Iam showing 2 bars on the fuel gauge.
Can you think of any other problem that may be causing the loss of power randomly.
Is it a loss of power? I have been caught out more than once by turbo lag when hitting the accelerator.
Discussion Starter #6
Hi Veeorty Deetoo and Tony1,
What it seems is that there is no response from the accelerator, you have to put your foot down that extra 2/3 inches for it pick up then it shoots forward at a rapid pace. It may not happen again for some time, but there is plenty of power - never did it once while I was towing a few weeks ago, but did so prior to towing I covered over a 1,000 miles this year towing.
I get that every now and then, I just put it down to turbo lag
the plot thickens... im steering away from water in diesel, boost pressure sensor, maybe an air leak on a vac pipe? hopefully one of the expert diesel folk will be along shortly:)
1 - 10 of 10 Posts
