1 - 12 of 12 Posts
· Registered
UPDATE:
Stripped out seats, now indoors drying and boot liner and there is a puddle of water on metal beneath parcel shelf. Also, if you put your hand between roof and liner, then it feels wet. So it does look as though shark fin/aeriel might be the problem. Whilst clearing snow from roof with a soft brush, the aeriel might have gotten knocked and the seal now might be broken. I will keep it stripped out and into a garage to get it resealed/repaired.
Thanks to everyone who responded - it is very much appreciated
Tonight my passenger exited my V40 with a wet bum! Upon checking the car, the entire rear seat is wet (especially where the upright backrest meets the seats. There is also cumulated water in the spare wheel well. Carpets/footwells are dry in rear and front. Checked windows which were closed and I have heat available via the ac/heater.
Help please?
· Registered
If the carpets are dry, it suggests that the water is probably coming in to the boot area from above, judging by your comments on the seats. Dry the rear door and hatch serals if they are damp, dry out the boot floor with paper and/or rages to soak up the water. Remove the carpeted floor, spare wheel if you have one, tools etc. so the metal floor is bare. Once dry, sprinkle talcum powder over the floor, and smear it around the entire hatch rubber seal, and the rear door seals. Using a hose, or preferably a watering can with a sprinkler, pour water over the back of the car in different areas, checking the door and hatch seals, and the boot floor for signs of water which will be obvious if it has run through the talc. It will hopefully indicate where the water is getting in.
· Registered
[/QUOTThank you and I will do as you suggestedE]
· Super Moderator
IIRC this has been posted before - something else to check is that the drain holes in the hatch surround aren't blocked.
· Registered
The roof antenna is another good p[ossibility. I'm sceptical about rear light clusters or hatch drain holes, as the boot floor is lower then the rear seat bases. For the seats to become wet from a leak around the light clusters etc. into the boot, the water would then have to travel uphill to soak the seat cushions.
· Registered
Discussion Starter · #12 ·
Okay that makes sense.
1 - 12 of 12 Posts
