Hi, was wondering if anyone with an older model of V40 ie 2010-2014 has had this kit fitted or DIY’d it yourself? Looks really interesting.
I own 2013 V40 D3 de lux nav
One person in India has done this. Read this - Volvo V40 Hatchback in India - Now launchedHi, was wondering if anyone with an older model of V40 etc 2010-2014 has had this kit fitted or DIY’d it yourself? Looks really interesting.
Cheers arvindnnOne person in India has done this. Read this - Volvo V40 Hatchback in India - Now launched
Hey mate, just wondering if your car has auto headlights, and if it does - does your map colour switch between light/dark mode to match the car's headlights? Mine seems to treat the switch being in the auto position the same as the headlights being on, even if they aren't actually onI've just fitted one to a MY2013 2.5 T5 Cross Country.
How did you route the aux to usb cable and where did you put the box?The other interesting thing - if you don't have AUX like me (because High Performance has usb sound only) you have to buy special usb to aux adapter from the same store, connect it into usb and to the Carplay box and select iPod in the original car interface (not in carplay).
I'm still in contact with the seller about front parking radar indication and will add details as soon as I've got answers)
you are a life safer... this is a great solution "Guide77" thanks for that adviseHello folks. Have now also installed this Kremersino Carplay in the V40 CC. Since I don't have an aux either, I ordered this USB adapter to plug into the center console. But I didn't want to run the cable under the entire center console and now use an adapter that plugs directly into the radio body and thus has a USB socket directly behind the radio. And there I was able to connect the USB adapter from Kremersino. Of course, the USB port in the center console is then out of order. Here's the part from Amazon that's actually for the Honda, but fits and works on the Volvo too. Unfortunately I can't post the link as I'm new here. Enter the following at Amazon "usb cable adapter keple flash drive". Then you should see a cable with a gray connector that fits right into the Volvo radio. At the other end is a USB socket.
