Over the last month or so I started to notice that the "Stop/Start" isn't as active as it normally is on the same journeys, I just put this down to the system holding off due to engine temp or not enough miles since starting the journey, I don't do a lot of mileage from the house to work.
Anyway, last week I took a spin down to the local shops and when I switched off the engine and opened the door a warning message popped on the screen that said "Low Battery Charge", this is the first time in four and half years since owning the car from new that I've seen this?
The message came on again when I arrived home and again the following morning, however, it has now stopped appearing over the last 4-5 days, but I've now noticed that the "Stop/Start" is not activating at all, and in the "My Car" menu it says "Stop/Start Not Available"? Obviously, this is linked to the "Low Battery Charge" warning but if this warning message has now ceased why is the "Stop/Start" still not available?
I've checked the battery with a multimeter and it shows 14v with the engine ticking over and 12v with the engine switched off.
I was then thinking that perhaps the battery is not holding its full charge and maybe I should leave it overnight before checking it on a cold engine, which I've done this morning, but it's still showing 12v!
Apparently, there are 2 batteries on the V40 but I can only get access to the main one in the engine compartment, could I be checking the wrong one?
Any advice is appreciated.
