Ventilation problem
5.3K views 4 replies 2 participants last post by  gwitt
#1 ·
The ventilation in my v40 is not working. There is just very little air coming through the outlets and it doesn´t change if if I set the fan speed to max.
Could anyone suggest things that could be broken and how to fix them. I have checked fuse nr.10 under the bonnet and that is fine.
Volvo v40
d2
2013
Discussion starter · #3 ·
Yes, the air flow controls are set to body. I have tried to set them to all available combinations. That does not change anything. The airvents are open.
There is also very little or no air coming onto the windscreen since I have condensation problems when its a bit wet outside. I have to open the windows to remove the condensation.
