This is for a Volvo 2013 RTI HDD with DVD.
Youtube Video on how to gain access to the dash: Youtube
The gear gaiter can be removed in a better fashion. Push your fingers on the leather and push the plastic surround upwards. You can remove the grill vents with your hands.
Behind the unit
Overview picture of Socket Connections
Remove all screws on the back of the unit.
The top part of the unit starts to lift up. But there is still a screw holding it down.
You can see a peek of the harddrive
The DVD Drive needs removed by 4 small screws
The central screw under the DVD drive needs removed
The Harddrive 4 screws can be seen.
Old ATA Connector. 80Gb. Slow UDMA 100.
Wide angle of parts
USB to ATA Adapter.
Check out how many time the unit has been switched on!
The disk wants initializing. But do NOT do it.
Acronis can't read the disk. Macrium can't either.
Forensic software can't figure out the file system. It let me take a copy of the harddrive. But cannot restore.
I did this at a friends and didn't have a Linux computer. DD should be able to copy the disk in to 1 file.
I will do this the next time. Link to other V40 Stuff (Still building)
Behind the unit
Wide angle of parts
USB to ATA Adapter.
